Is there a way to type in the timeline in cc 2017?
Krista Hoffmaster
on May 12, 2018 at 7:18:44 pm
I tried pressing ALT to open it, but it did not work.
Dave LaRonde
Re: Is there a way to type in the timeline in cc 2017?
on May 12, 2018 at 9:50:26 pm
There's just one way to do it.
You add a layer to the comp. You highlight the layer. You hit the asterisk key on the numeric keypad. This creates a marker. If you double-click on the marker, you can add text to annotate the marker. I'm not sure, but you may be limited to 64 characters. You'd have to check for sure.
When you think about it, this is a pretty handy way to do it. You can leave notes to yourself or others on what happens at a particular point in time.
Dave LaRonde
Promotion Producer
Kalleheikki Kannisto
on May 13, 2018 at 4:17:30 pm
What you're showing in your screenshot is an expression input field. That's not a place for making notes on the timeline. It's for automating functions and effects with javascript-based expressions language.
Senior Graphic Designer
