How to animate a 2-D Image?
Jacky Ern
on May 12, 2018 at 4:12:39 am
In this video, https://www.youtube.com/watch?v=dLe1uUqpm7w, this image: https://yande.re/post/show/338879 is used and parts of it is animated, like the hair and the scarf. How can I achieve this effect? If it's not After Effects can someone tell me a certain program I can use. Thank you guys so much as always.
Kalleheikki Kannisto
Re: How to animate a 2-D Image?
on May 12, 2018 at 12:41:19 pm
Yes, it's After Effects. You cut out the character and add some puppet pins, then add a wiggle expression to the puppet pins that you want to have moving around.
Senior Graphic Designer
