Infinite zoom motion graphic
Alfio Santini
on May 10, 2018 at 12:30:37 pm
Hello people. I'm new in the world of after effects and animation. I'm trying to create the infinite zoom loop effect with the pony image. I reached this result but the animation doesn't have a continuous movement like the example of the first image. Can anyone help this dumb novice with any advices?
Steve Bentley
Re: Infinite zoom motion graphic
on May 10, 2018 at 5:26:46 pm
I think the problem is that scaling is an exponential process (scale something by 200% and the shape becomes 4 times the area, scale by 400% it becomes 16 times the area)
And when you do that over time the speed of the scaling appears to change speed.
So as the object scales up you have to slow that scaling down so that it matches the speed of the incoming footage that is just starting its scale.
Alfio Santini
on May 11, 2018 at 8:40:25 am
I resolved with exponential scale for the scale and easy ease for position :D
