Using a video as texture in Elements 3d
Luis Garcia
on May 8, 2018 at 8:35:30 am
Hi! I have a question... I would like to use a video as a texture in elements 3d. When I have tried it with a cube created into elements 3d, I can use it without any problem, but whenI have tried it into a imported polygon (imported from hexagon 2.5 wit .obj extension) the texture doesn´t appear into the face of this new polygon, like in the case of the cube. The texture turn into a smooth brown but I can´t see the video into it.
I would like to do that... Please, help.
Thanks in advance!
Cheers
Mark Whitney
Re: Using a video as texture in Elements 3d
on May 8, 2018 at 4:01:43 pm
Sounds like a UV mapping issue with your new poly. You'll have to dig down into E3D and look at what it's defaulted too for that geometry. Should be a quick & easy tweek.
