Reduce Chatter - Key Cleaner
Filip Stillerska
on May 5, 2018 at 7:23:15 pm
I always check this box, even if I don't see any noticeable chatter, just to make sure.
Is there ever a reason or time when you shouldn't use "Reduce Chatter" in Key Cleaner? Why is it defaulted to unchecked?
Roei Tzoref
Re: Reduce Chatter - Key Cleaner
on May 6, 2018 at 6:06:39 am
one obvious reason not to use it is that it's memory intensive. You could use the free plugin fx console to customize the default parameters of this effect for later use.
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
Steve Bentley
on May 7, 2018 at 5:30:00 pm
It also softens the key so in effect removes information that could be useful for things like fine hair.
Every key is different (even from the same shoot) so to do film quality keys you need to consider each shot on its own.
