Change stroke to to dashed mid way through path?
josh mutscheller
on Apr 30, 2018 at 2:08:29 am
Hi there,
I am making an animated arrow but need the stroke running along the path to change to dashed after the kink ( image supplied )
Ive managed to make the path and arrow along the movement, but cant get the path stroke to change mid way!
cheers,
Josh
Kalleheikki Kannisto
Re: Change stroke to to dashed mid way through path?
on Apr 30, 2018 at 9:00:33 am
Simplest way would be to cut the path into two.
Second option is to make two copies and use trim paths on the top copy that has the solid line.
Then there are plugins like Ourobouros that can do fancier things, although probably an unnecessary complex tool for something like this.
Senior Graphic Designer
