Demons...
Eric Santiago
Demons...
on Apr 25, 2018 at 2:34:22 pm
Am I the only one that's been told to wear headphones at work due to the annoying demo noises AE makes when doing RAM Preview with audio?
Why did AE change their audio preview option?
I know there are workarounds but man why f*ck with something that worked well in the past :P
Walter Soyka
Re: Demons...
on Apr 25, 2018 at 3:46:38 pm
The entire preview approach changed in Ae CC 2015, as part of Adobe's modernization of Ae, to try to improve performance.
Two major changes:
1) The UI and the renderer have been split into separate threads. This really improves responsiveness; the renderer no longer blocks the UI (and vice versa).
2) Preview can happen without rendering the preview range to RAM first. When the comp is simple (or highly GPU-accelerated), you can preview in real-time, right away.
If you want to emulate Ae's classic RAM preview approach, check the "Cache Before Playback" option. (I think this is enabled by default on Numpad-0.)
Walter Soyka
Roland R. Kahlenberg
Re: Demons...
on Apr 25, 2018 at 9:12:20 pm
You can prevent the 'demo' noises by going to AE's Preferences>Previews and enabling "Mute Audio when Preview is not Real-time".
PathSlicer - Advanced AE Shape Layer Effect
http://www.broadcastgems.com/pathSlicer
- create highly customizable custom animated typefaces
- create amazing transitions
- create cool lower 3rds and panels
- create burst effects
Do it all on a single Shape layer with minimal keyframes.
TypeGEMs - The Most Complete Type Tool Effect for AE
http://www.broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
BorisFX mocha Certified Instructor
