Black Pixels and Black Frames with Element 3D
Petar Georgiev
on Apr 24, 2018 at 5:49:04 pm
Hello.
I am having a problem. On my 3D models I get black pixels on random frames and from time to time some of the frames are completely black. I uploaded a short rendered video where you can see the black pixels flickering at the end. I'm with the latest drivers for my GPU. I'm with GTX 1080, 32 gb ram (3000 MHZ), core i7-8700k.
Cassius Marques
Re: Black Pixels and Black Frames with Element 3D
on Apr 24, 2018 at 7:09:59 pm
Is ambient occlusion on? Can you move the needle to a frame that shows the blacks and turn it off?
Cassius Marques
http://www.zapfilmes.com
Petar Georgiev
on Apr 25, 2018 at 9:42:24 pm
I have AO on but I am 100% sure it's not what's causing the problem. I will go back from version 15.1 to 15.0 to see if my problems will disappear.
Steve Bentley
on Apr 27, 2018 at 2:34:33 pm
It could be a depth thing too - two layers occupying the same z depth and AE flips back and forth between the two of them as the round off calculations give different results on different frames.
