Tracking video after
Gabriel Ribeiro
on Apr 18, 2018 at 12:42:44 pm
Wonder if someone could help me. just need a light here ehehehhe
I need to create tracking on a book made in 3D so I could add some text (this vid https://www.shutterstock.com/pt/video/clip-6271898-stock-footage-three-book...
but I'm having a hard time to create, I don't know much about tracking, can someone give me a direction on how to track? so I can add some text or anything that follow the camera?
Thanks so much =D
Max Haller
Re: Tracking video after
on Apr 19, 2018 at 3:15:52 pm
Check out this tutorial about tracking text to walls
Same ideas should apply here if you're trying to add text/images to that first page. You'd just have to roto out the cover so the texts reveals as the books opens. Otherwise it should be pretty similar to that tutorial.
But there's really a lot of ways of to track the text into the book. You could probably do it with normal tracking with rotation and scale checked also.
Or if you want to try tracking it in mocha check out this quick tutorial too :
These should give you a pretty good over view of your options, good luck.
