Trying to recreate an effect (Something similar to smoke text)
Cypert Costa
on Apr 8, 2018 at 12:39:01 pm
Hello, I'm trying to recreate this effect
To do that I've tried converting a rectangular shape layer to an adjustement layer, applying here the effects "Turbulent Displace", "Fast Blur" and "Wave Warp", and moving this layer to make it them stop effecting the text below, but I've 2 problems, the effects it's not the same, it's kind of similar but not close enough and I the second one is that I don't know how to make the transition between the part with the effect and the one without seamless (Sorry for my english, I've attached an image to try to explain what I mean)
Kalleheikki Kannisto
Re: Trying to recreate an effect (Something similar to smoke text)
on Apr 8, 2018 at 4:42:17 pm
What I suspect they have done is use an animated soft fractal noise and used that noise to drive both displacement and lens blur effects. Then applied a levels adjustment on the fractal noise to bring it from full white to full black (with the fractal in shades of gray in between those extremes).
Senior Graphic Designer
Cypert Costa
on Apr 8, 2018 at 5:55:30 pm
Thank you for your answer, I'll try it
John Cuevas
on Apr 9, 2018 at 3:20:51 pm
Looks very much like this old technique:
Flowing Title Effects
Project files are way out of date, but if you follow the steps you will get basically the result you are looking for.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Cypert Costa
on Apr 13, 2018 at 9:37:23 pm
Thank you, I'll try it this weekend
