How and which effect to use?
dave trotz
on Mar 31, 2018 at 1:18:29 am
I am trying to make a nice intro for a website and I want to get something similar to this :
I know this is a type of liquid particle or ink particle effect, but is there any specific effect that you guys would suggest me to use? I've seen a lot of Particle FX online but none of them seem to make such beautiful fluid effect.
Thanks for your help,
Dave
Steve Bentley
Re: How and which effect to use?
on Mar 31, 2018 at 6:18:53 pm
There are so many ways to create that but in that example it looks like they have attached circles to the TrapCode Form plug in at each vertex and used the stock wiggle out of the box. Trapcode Particular could also do this.
Kalleheikki Kannisto
on Apr 2, 2018 at 7:40:01 am
Since the particles disappear after some time, Particular is the way to go. Form has persistent particles.
Senior Graphic Designer
Cassius Marques
on Apr 2, 2018 at 12:52:00 pm
[Kalleheikki Kannisto] "Form has persistent particles."
Thats true, but you can still map out with opacity. I usually use form for "text-to-sand" effects, even though the setup usually takes a lot longer and you'd probably need to time reverse things. But particular can't match the options...
Cassius Marques
http://www.zapfilmes.com
on Apr 2, 2018 at 2:40:45 pm
Quite true. The sample video looks like Particular with a layer map emitter, but you can do virtually the same in Form. Probably better.
dave trotz
on Apr 3, 2018 at 11:17:07 pm
What do you guys mean by 'Form' ?
Steve Bentley
on Apr 3, 2018 at 11:51:08 pm
Form is a plug in from the Trapcode set of plug ins - it is available separately but does cost.
Its a particle system that's based on a mesh.
Its available from Red Giant and Tool Farm and others.
dave trotz
on Apr 4, 2018 at 1:40:43 am
Oh ok I found : Trapcode - Form.
Thanks all for your help, I will try to give it a try as soon as I can.
Cheers!
Richard Garabedain
on Apr 4, 2018 at 4:23:30 pm
its cc ball action i think..if you add the cc ball action, and start to scatter and twist it...make another copy with smaller balls, then do a linear wipe on both it would work decently well...since you probably dont want to pay that muuch for trapcode form... . the shine is cc light sweep.
