How to animate a tennis ball roll
Ashley Davis
on Mar 28, 2018 at 9:11:12 am
I want to create an animation wherein a tennis ball rolls into frame and stops. Ideally, make it look realistic and that its rolling in 3d space rather than just moving into frame.
Is there a relatively simple way of doing this? or even better, do stock vector videos/animations exist? Is this a thing?
Richard Garabedain
Re: How to animate a tennis ball roll
on Mar 28, 2018 at 2:37:52 pm
well do you have element 3d? If not you could do a 2d animated roll.
Steve Bentley
on Mar 28, 2018 at 6:59:55 pm
You could also use the CC sphere to simulate this but its a little tricky because it's not really 3D.
But just for a 2D ball , you can put an expression on the ball - you keyframe the rotation and then apply the math of: distanceTravelled = 2*Pie*R*rotationAngle/360
I couldn't figure out how to post the symbol for Pie
R is the radius
This way the balls "sticks" to the ground as it rolls and doesn't spin at the wong rate.
