Mute and unmute effects on the go
Telion Fondrad
on Mar 28, 2018 at 6:50:14 am
I don't know how to call this so it might be a reason why I can't find a solution. All I need is to disable and enable effects on the timeline when needed since I am just adding additional effects to the already rendered project. Is that possible to make that this way or I must split all the scenes in my video and apply effects to those which need it?
Richard Garabedain
Re: Mute and unmute effects on the go
on Mar 28, 2018 at 2:40:13 pm
Yes..you see your layer has the motion blur option and the 3d option...well see that fx symbol. if you uncheck it, all the effects on that layers are turned off.
