Element 3D How to Align 2 objects by a given face or stick two object faces together
Travis Landers
on Mar 22, 2018 at 4:41:54 am
Does anyone know of a convenient way to align two faces of say... two cubes... meaning stick the top of one cube to the bottom of another cube with ease? I want o align or stick several cubes together and I wanted to use element but was surprised when I couldnt find any visible way to do this...
Am I missing something?
Cheers,
Trav
Mark Whitney
Re: Element 3D How to Align 2 objects by a given face or stick two object faces together
on Mar 22, 2018 at 5:05:02 am
[Travis Landers] "Am I missing something?"
Apparently you are.
I suggest you review the basics of the Particle Replicator and Look.
http://www.videocopilot.net/docs/element2/animating_3d_objects/particle_rep...
http://www.videocopilot.net/tutorials/3d_replicator/
Richard Garabedain
on Mar 22, 2018 at 9:39:32 pm
from two different groups? or in the same group...i imagine different otherise the answer is easy...and any 2 sides..or 2 specific sides...i mean...the animation engine might work for you..Tell us what your doing exactly...is the only way this works...i know
Travis Landers
on Mar 23, 2018 at 4:00:14 pm
Well originally I meant from one group.... Actually I knew nothing about the particle replicator.... i just looked up align two objects and didnt get much search love...
Now seeing how it works... I would indeed like to have two groups or more and line them up side by side...
I am thinking I can replicate my planes then use nulls like I saw in a vid to place one plane of cubes directly next to the other...
Ultimately I have kind of a complex final plane made of smaller groups in mind.... no photoshop now to make a pic but basically four squares that are cut by strips... i tried to represent it with numbers below... each number is a different texture type
111192222
111192222
111192222
111192222
888878888
333394444
333394444
333394444
333394444
So in that i have 7 different textures... above is how I think I could do what I want and I guess i just use the replicator with multiple groups and “stick” them together using nulls BUT...
really I just want a plane of cubes and be able to change any cubes texture whenever I want... that would be awesome. So I could highlight strips or individual blocks or whatever.
I realize this is kind of abstract from the original question. There is no doubt the replicator can get me a plane of cubes that are aligned well... so that is great. However, perhaps there is even a better way to get to where I want.
Thanks Mark Whitney
New to element and 3d so cheers
