After Effects project as template plus possible to clone layers?
Thomas Frank
on Mar 16, 2018 at 9:48:13 am
I will like to create a animated slide show in after effects which then the user can replace the content (images) in the new future.
My question is how would someone go by this? I have seen other templates but its a bit confusing since not possible to view all comp in the main comp.
Also is it possible to clone a later like Apple Motion where the clone can adjusted but when the original media is replaced the cloner is also update with that image?
Thx
Michael Szalapski
Re: After Effects project as template plus possible to clone layers?
on Mar 16, 2018 at 8:20:30 pm
Most templates do it by tucking everything away in a folder in the project panel except for the composition you want them to render (which is titled "MAIN RENDER" or "RENDER ME" or something) and a folder containing pre comps that they need to put their text/logo/images in. That way, when they place their images in the respective pre comps, everything you've set up will work!
- The Great Szalam
