Scale First Shape in Repeater
Liam Campbell
on Mar 10, 2018 at 8:43:17 pm
I'm making a video buffer animation and I have a circle of curved rectangles,( as if you dashed a circular line) and around the circle they fade from white to black. All I want is the white rectangle to be larger so as it animates only the white rectangle is a little bit bigger? Why isn't this a feature in repeaters?
Dave LaRonde
Re: Scale First Shape in Repeater
on Mar 11, 2018 at 2:06:36 am
I can't say for sure, but I would guess it's because the repeater's intended to REPEAT the first shape.
Well, it makes sense to me, anyway.
You can always go with Plan B, which would be to have one layer with a slightly larger shape, and use ththe repeater on a layer. with normal-sized shapes.
Dave LaRonde
Promotion Producer
