Does more RAM will speed up the exporting time of hd video in adobe premiere pro cs6?
Freda Yeo
on Mar 10, 2018 at 6:37:07 am
My video is mts format (AVCHD) 1hr 5min long, it run smoothly no need to render (not see the yellow line in timeline), I just do some edt add title and transition, after that i try export to mpeg2 format 1440x1080, 1pass, Target 15, but it take about 53min to finish the exporting. I already checked "Use Previews" while exporting. I want increase the speed of exporting time, so add More RAM can speed up a bit ?
My Computer Specification:
Windows 7 64bit OS
Intel Core i5 7400 3Ghz
Memory: 8Gb RAM (2 x 4gb)
Geforce GTX 1060 OC 6gb
3 hdd (2x1tb & 1x500gb)
Dave LaRonde
Re: Does more RAM will speed up the exporting time of hd video in adobe premiere pro cs6?
on Mar 10, 2018 at 4:16:41 pm
To answer your question, 16 GB would be better.
Now I ask a question -- what are you using AE for with an hour-plus clip?
One minute is a long time in AE. You may be using the wrong application. This is why I ask.
Dave LaRonde
Promotion Producer
Jim Scott
on Mar 10, 2018 at 11:29:56 pm
Dave,
It looks like he misposted in the AE forum, which prompted your very applicable question. His original question was about RAM for Premiere Pro.
Freda Yeo
on Mar 11, 2018 at 1:33:35 am
Sorry, is " Adobe Premiere Pro CS6", not After effect, so add more RAM will speed up exporting time of " Premiere Pro HD video?"
And i have one more question about "After Effect", i saw a post maybe is other website, it said to speed up the exporting time of the After Effect project is better render the effect timeline first then just go exporting, but i cannot render the whole timeline (some heavy effect about 30 second) , so is upgrade the RAM will be solve this problem or any other setting to speed up exporting time?
