Cineform proxy with alpha in CS6
Anmol Mishra
on Feb 28, 2018 at 10:46:38 pm
Hi. I am on after effects CS6. I have a chromakey comp. I right clicked on the comp -> create proxy -> movie
In the render options I chose cineform, rgb+alpha, trillions+, premultiplied unmatted.
The file shows a black background in VLC, qt7, as well as in after effects.
What am I doing wrong?
Dave LaRonde
Re: Cineform proxy with alpha in CS6
on Feb 28, 2018 at 10:58:56 pm
What kind of operating system do you have? CS6 is not okay to work on Mac High Sierra, for instance.
Dave LaRonde
Promotion Producer
Anmol Mishra
on Feb 28, 2018 at 11:34:49 pm
I'm using Sierra. CS6 works fine there. However I have experienced the same problem from mountain lion days.
Somehow the alpha channel is coming as a black layer.
Anmol Mishra
on Mar 1, 2018 at 9:11:45 am
Just for fun I rendered using prores 4444. No issues with alpha channel.
Dave LaRonde
on Mar 1, 2018 at 2:46:22 pm
Lesson learned! Cineform proxies don't support alpha channels.
Dave LaRonde
Promotion Producer
Walter Soyka
on Mar 1, 2018 at 3:16:54 pm
[Dave LaRonde] "Lesson learned! Cineform proxies don't support alpha channels."
Well... CineForm does support alpha, so I don't think the matter is wrapped up yet.
CS6 was before native CineForm support was added to Creative Cloud. I think that Anmol may need to choose a CineForm profile that supports alpha in the Codec Options of the output module, but it's been a while and I don't remember what the dialog looks like. Those screenshots I asked for below will help.
Walter Soyka
Anmol Mishra
on Mar 4, 2018 at 8:25:18 pm
Hi. Here are the screenshots.
12225_screenshot20180305at1.48.30am.png.zip
Walter Soyka
on Mar 1, 2018 at 10:49:07 am
It's been a while since I've used CS6. Can you post some screenshots that show your output module settings, and also the codec options for CineForm?
Walter Soyka
Anmol Mishra
on Mar 4, 2018 at 8:28:03 pm
Codec Options are here.
Walter Soyka
on Mar 4, 2018 at 8:45:40 pm
Click "Enable RGB encoding (4:4:4)", then click "Enable Alpha Channel (4:4:4:4)." Save those settings into your output module.
Walter Soyka
Anmol Mishra
on Mar 4, 2018 at 9:18:51 pm
I get an error - Output module failed.
I had tried that option initially years ago when I started using CF. Still causes problems.
