Mask Tool Not Working Properly
Krista Hoffmaster
on Feb 21, 2018 at 10:43:02 am
I have been having an issue with making a mask. I have done this before and made sure I did everything properly but for some reason it is not working. The mask layer won't conform to the mask.
Walter Soyka
Re: Mask Tool Not Working Properly
on Feb 21, 2018 at 10:54:20 am
What other effects do you have applied to the layer? You may need to precompose or use a track matte instead of a mask.
Walter Soyka
Krista Hoffmaster
on Feb 21, 2018 at 10:59:19 am
I precomposed it and the only effect is fractal noise. I tried it again and I think I may have fixed it. I have to work around mask it and then invert it for it to show.
Krista Hoffmaster
on Feb 21, 2018 at 11:01:27 am
I am unable to feather out the mask now. It only wants to expand.
Walter Soyka
on Feb 21, 2018 at 11:05:46 am
Can you post your AEP? (No footage, just the AEP is fine.)
Walter Soyka
Krista Hoffmaster
on Feb 21, 2018 at 11:10:13 am
12191_majornewaefile.aep.zip
Walter Soyka
on Feb 21, 2018 at 11:18:18 am
There was no mask on the solid layer in "sprite," but I created one and was able to mask, feather and expand it as expected.
I'd first suggest rebooting; it that doesn't work, clear your cache (Edit > Purge > All memory & disk cache); and if that doesn't work, reset your preferences (hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while starting After Effects).
Walter Soyka
Krista Hoffmaster
on Feb 21, 2018 at 7:20:33 pm
Would you mind sending me that file?
Walter Soyka
on Feb 22, 2018 at 10:02:10 am
Absolutely. Here's the file:
12196_12191majornewaefilecc14.aep.zip
And here's a quick screen grab showing everything working with the mask:
Walter Soyka
