how to Render 4608x128 mp4
Peter Jones
on Feb 21, 2018 at 9:50:50 am
Is it possible to render a 4608x128 mp4 mp4 from AfterEffects or via Media Encoder?
is this H265 which Media Encoder doesn't support yet?
The AV company won't accept Prores codec
- Pete
senior editor
Walter Soyka
Re: how to Render 4608x128 mp4
on Feb 21, 2018 at 10:48:26 am
4608 is wider than the H.264 standard allows, so Adobe Media Encoder will not produce this out-of-spec file.
However, ffmpeg doens't care and will happily produce a file with those specs. You could transcode a render with ffmpeg from the command line, or you could use render directly from Ae with AfterCodecs:
https://aescripts.com/aftercodecs/
Walter Soyka
Peter Jones
on Feb 21, 2018 at 1:03:03 pm
Thanks Walter.
Purchased the Aftercodecs plugin and works fine.
- Pete
senior editor
