Motion Tracking After Effects footage with Cinema4D
holly amott
on Feb 20, 2018 at 3:25:47 pm
Hey guys,
I'm trying to get green-screened footage onto an interior in Cinema4D using AE, but it's all wacky.
I've motion tracked some footage in after effects (position + rotation) which is fine, applied it to a null etc, and I wondered if it was possible to make the AE comp camera Cinema4D uses move correctly using the null?
I made a camera, attached the camera to the null, and played it back but the movements of the camera are so wacky, exaggerated and all over the place it looks ridiculous. I tried upscaling the 3d interior model and going back to AE thinking it was just too small but the result is still the same.
However it works fine with a still picture or video. Is there a way to do this? My Cinema4D is using the AE comp camera.
I'm still learning, please don't kill me if I did something stupidly wrong 😅
Thank you!
Walter Soyka
Re: Motion Tracking After Effects footage with Cinema4D
on Feb 21, 2018 at 11:00:40 am
[holly amott] "ve motion tracked some footage in after effects (position + rotation) which is fine, applied it to a null etc, and I wondered if it was possible to make the AE comp camera Cinema4D uses move correctly using the null?"
You should use the 3D Camera Tracker instead of a 2D point tracker. This will solve for a virtual camera that matches the movements of the real-world camera.
Walter Soyka
