Dynamic Text in UI Panel Extendscript
phil largilliere
on Feb 19, 2018 at 2:02:51 pm
Hi everyone,
I'm tyring to create a UI Panel to get some currently expressions codes for my colleagues, but I really don't know how to display infomartions in my text zone.
I already wrote this, it's pretty dirty for now, but this is how it should work :
My text zone is empty, then when I click on one of the radio button (or on the getCodeBtn), it will look for differents codes (I will enter them into a array) and display it in my text zone...
exprCode = "";
function myScript(thisObj) {
function myScript_buildUI(thisObj) {
var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "Menu Tests", undefined, {resizeable:true});
res="group{ \
orientation:'column', align:'left',\
code : Group {orientation:'row', alignment:['fill','fill'], spacing:5, \
myRadioButton01: RadioButton{text:'Opacité', tooltipActive:'2 Lettres'},\
myRadioButton02: RadioButton{text:'Texte', tooltipActive:'2 Lettres'},\
myRadioButton03: RadioButton{text:'Code', tooltipActive:'2 Lettres'},\
myRadioButton04: RadioButton{text:'Flash', tooltipActive:'2 Lettres'},\
textZone : Group { \
orientation:'column', alignment:['fill','fill'], spacing:5, \
heading: Group {alignment:['fill','top'], lbl: StaticText { text:'Code à copier', alignment:['left','bottom'] }, \
getCode: EditText { text:'', properties:{'multiline':true}, alignment:['fill','fill'], minimumSize:[500,120] }, \
cmd: Group { \
alignment:['fill','bottom'], \
getCodeBtn: Button { text:'Chopper un code', alignment:['right','top'], preferredSize:[-1,20] }, \
myPanel.grp = myPanel.add(res);
myPanel.grp.cmd.getPropPathBtn.onClick = afficheCode;
myPanel.grp.textZone.getCode.text = exprCode;
function afficheCode()
exprCode = "Ta mémé !"
alert(exprCode);
myScript(this);
this.parent.parent.textZone.heading.getCode.enabled = true;
myPanel.layout.layout(true);
return myPanel;
var myScriptPal = myScript_buildUI(thisObj);
if(myScriptPal != null && myScriptPal instanceof Window){
myScriptPal.left();
myScriptPal.show();
myScript(this);
Hope it's clear enough :/
Thanks for your help
Joseph Simons
Re: Dynamic Text in UI Panel Extendscript
on Feb 20, 2018 at 3:46:34 am
Hi Phil,
I can't directly answer your question, but found your post as I was attempting to do something similar. Your base code looks exactly like what I've been referencing in David Torno's online course, so I'm assuming you're in a similar place as I am.
I found this resource for all the possible edittext properties, which I think you'll find useful.
http://jongware.mit.edu/iljscs6html/iljscs6/pc_EditText.html
Good luck with your coding endeavors!
Joseph
phil largilliere
on Feb 22, 2018 at 1:36:27 pm
I didn't find how it works... Do you know a place where I can find more tutorials as David Torno did on provideocoalition ? Or on Adobe website ?
