Layer Copy-Paste Issue
Dan Robert
on Feb 18, 2018 at 9:17:46 am
Hello !
Newbie here, I would have a short question.
I would like to copy-paste the same 4 layers in the same timeline but when I do this it just dissapears.
I have linked two screenshots of my issue.
https://imgur.com/a/pKdQo
https://imgur.com/a/BSLER
Thank you !
Dave LaRonde
Re: Layer Copy-Paste Issue
on Feb 18, 2018 at 3:59:29 pm
I see that you have an Adjustment Layer labeled, "Control Layer". What is it controlling? I bet you'll find the source of your problems in it.
Incidentally, you probably don't need to make it an adjustment layer. It's clearly at the bottom of your other layers, and adjustment layers are intended to be vehicles containing effects to influence any layers below them. No layers below yours -- applied effects don't work. You could probably use a solid with equal success. Perhaps a Guide Layer.
Dave LaRonde
Promotion Producer
