Make an object reflecting on real water footage in AE CC 2017
Margaux Millet
on Feb 17, 2018 at 5:45:00 pm
Hello everyone,
I have a problem to make an effect in AE. I have a comp representing an animated graph (I use the motion tracking) in 3D. I also have a footage of a river. I want my graph to reflect on the river. Do you know if it's possible and if so, how could I create this effect?
Thank you very much in advance
Jim Scott
Re: Make an object reflecting on real water footage in AE CC 2017
on Feb 17, 2018 at 7:16:34 pm
Duplicate your graph layer. Make it 3D. Adjust its position, orientation and scale so as to make it appear as a mirror image of the original in the plane of the water. Reduce its opacity to make it appear as a reflection. Apply Effect > Distort > Displacement Map and select the water footage as the displacement map layer. Adjust the displacement settings to your satisfaction.
Hope this helps.
