Has this effect/ technique a name?
Jasford Muldoon
on Feb 14, 2018 at 9:40:04 pm
It happens between 0:24 and 0:26 in this video, with the 3d field with the glowing 3d rings, nnot sure if this is even done in AE or something like c4d but it looks very amazing, any info would be appreciated
Jasford
Spencer Tweed
Re: Has this effect/ technique a name?
on Feb 14, 2018 at 10:34:07 pm
Those are just rings in 3D space, nothing too special. Check out videocopilot.net, and download "saber". You can use that to create a similar looking ring on a card, then duplicate it a few times and offset it in z space.
- Spencer
Jasford Muldoon
on Feb 15, 2018 at 12:07:59 am
Thanks spencer, Ill give it a shot and see what happens, I have the plug in saber however ive not had a chance to use it yet should be fun!
Jasford
Eric Santiago
on Feb 15, 2018 at 1:02:27 am
Besides the effects its when and where it's used.
Perfectly placed to make you feel you went from real to 3D space.
All about the edit and how you place it with this one.
Jasford Muldoon
on Feb 15, 2018 at 1:17:33 am
Thanks for the info eric!
