Circle Trim Path Issue
Ashley Ripka
on Feb 9, 2018 at 4:06:00 pm
Hoping someone can help me with this, I've never had this issue before and I cannot figure out what the problem is.
I am animating a circle trim path around a number. Everything is fine until it gets about 75% around and then it glitches. I am attaching a couple screen shots.
Here's a before:
Here's an after:
Thanks in advance!
Roei Tzoref
Re: Circle Trim Path Issue
on Feb 9, 2018 at 5:50:39 pm
did you by any chance start with a parametric shape and then converted to bezier by right click convert to bezier path? because if so this procedure is buggy for animation unless you re-set the first vertex.
highlight the path, see where the first vertex is (it has a square box)
then select just that vertex and right click->mask and shape path>set first vertex.
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
Ashley Ripka
on Feb 9, 2018 at 8:51:08 pm
I used a shape layer with no fill and a stroke only. I tried what you suggested and it's grayed out in my menu.
Roei Tzoref
on Feb 9, 2018 at 10:14:10 pm
Do you see the path property? Make sure just that vertex is selected.
Roei Tzoref
Roland R. Kahlenberg
on Feb 10, 2018 at 9:15:29 am
This is very likely a cache issue. Edit>Purge>All Memory & Cache to see if it helps. If not, then restart AE.
TypeGEMs - the Definitive Type Gizmo for AE
http://broadcastgems.com/typegems/
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
http://www.broadcastgems.com/mographintensity_shapestext/
Ashley Ripka
on Feb 12, 2018 at 2:35:37 pm
That was my first instinct, didn't work.
I ended up just recreating the shape layer with the trim path and it seems to be working.
Dmytro Korolkov
on Jul 28, 2018 at 12:42:58 pm
cache reset was my resolution. Interesting that Media encorder use AE cache for rendering.
Ashley Ripka
on Feb 12, 2018 at 2:34:59 pm
Nothing seemed to work, so I just recreated the shape layer with the trim path animation and it seems to be working fine.
Thank you for trying to help.
