After effects rendering out radial gradients
Ceri Allen
on Feb 8, 2018 at 11:08:13 pm
Hi
I am rendering out graphics that have a radial gradient on a block colour as a background.
When I render them out you can see the staggering of the gradient quite dramatically.
I have experimented making the gradient using the gradient layer style, ramp effect and masking on a solid, this doesn't make any difference.
I have experimented rendering as H.264, apple pro-res, animation codec and DPX sequence. The DPX and animation give the best result though it is still not completely smooth.
Is there any way around this? As it is at the moment I am concerned if it would fail QC checks.
It will be inserted into an edit I think in Premiere so if there is a more advisable format to render out in then needs to be suitable for this.
