use luma map to displace position
johnny mabie
on Feb 8, 2018 at 1:44:17 am
I would like to use a luma gradient map to effect the position value on individual layers. For example:
Start with:
a) a row of shape layers laid out horizontally across the comp
b) a white-to-black horizontal gradient map off the left side of the comp
As the gradient map moves from left to right across the comp, each shape layer's y-position increases as the luma value behind it increases from black to white.
There must be an expression or string of expressions that can achieve this. Any ideas?
Cassius Marques
Re: use luma map to displace position
on Feb 8, 2018 at 11:31:23 am
You have to use the sampleimage function to drive (in any way you like) the yPosition value of your layers...
Something like this: 12142_sampleimage.aep.zip
Cassius Marques
http://www.zapfilmes.com
