Moving an object along a growing line
Sarah Bott
on Feb 7, 2018 at 3:59:56 pm
Hi everyone,
I'm wondering if you can help me simplify my project.
I've built an animation that has a blinking dot traveling from location to location on a map. As the dot travels, a path appears showing where the dot has been.
Right now I have the line animating separate from the dot, but each the customer asks to retime things it is very time consuming since I have to retime the line separate from the dot. I'm wondering if there is a way I can control the growing line along with the dot so I'm only adjusting one set of keyframes when I need to make edits.
Thanks for any help!
Dave LaRonde
Re: Moving an object along a growing line
on Feb 7, 2018 at 6:20:29 pm
It's hard to say.
Please describe the procedures you currently use to animate the line and move the blinking dot.
I would tend to use an older technique where both layers are animated separately, and if it took me more than a minute to make the timing change, I would be greatly embarrassed and would consider going back to the metaphorical AE School.
Dave LaRonde
Promotion Producer
Joseph W. Bourke
on Feb 7, 2018 at 7:15:23 pm
Sarah -
Would something like this help:
https://aescripts.com/speed-lines/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
Walter Soyka
on Feb 7, 2018 at 7:32:11 pm
If you're using the latest version of After Effects, you can make use of the new pointOnPath() expression to link the position of one layer to a path on another.
Here's an example for your case that you could modify:
12140_dotonpath.aep.zip
Walter Soyka
