4 minute slide show fails to export
Andrew Davis
on Feb 5, 2018 at 6:44:49 pm
I am editing a 4 minute slide show with 43 pictures in it. I want to export it to for use online (retirement video for a friend). It does have a good amount of layers with some glares, etc. I tried to export to H.264 and it fails 31 minutes in and continues to take forever to render.
What can I do here to correct this? What is the best way to export this?
John Cuevas
Re: 4 minute slide show fails to export
on Feb 5, 2018 at 7:28:35 pm
Without knowing your computer, settings... I would suggest exporting as an image sequence and then import that into your editor of choice for the final. Even if the render fails, you can just pick up with the last image that correctly rendered.
Johnny Cuevas, Editor
ThinkCK
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
