Pressed shortcut by mistake - color change
Leon Earl
on Feb 3, 2018 at 11:45:39 am
Hi, I must have pressed a shortcut by mistake as the colors in my comp have all changed. I can't work out how to undo it (see image).
It looks like the shortcut is related to the green/red channels (as these colors have all been inverted) but other colors seem unaffected. I've googled about but without the keyword (i.e. whatever shortcut I'm pressing), it leads me nowhere.
Thanks for reading and hopefully someone can save me!
L
Dave LaRonde
Re: Pressed shortcut by mistake - color change
on Feb 3, 2018 at 5:20:58 pm
Why don't you just Undo? Cmd-z Mac, Ctl-z Win. AE has 99 levels of Undo.
Depending on what you've done since the mistake you may have to undo many times. And you will lose all the things you did between now and then.
Dave LaRonde
Promotion Producer
Roei Tzoref
on Feb 3, 2018 at 8:17:39 pm
undo won't change a preview setting.
check your Channel settings:
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
