Is there an effect for this?
Ornella Jacobson
on Feb 2, 2018 at 10:56:10 pm
Hey folks
Simple question, I guess: Im sure there must be an effect or plugin to recreate this effect, but i just can't find it.
Any ideas?
Cheers,
Ornella
Dave LaRonde
Re: Is there an effect for this?
on Feb 2, 2018 at 11:05:35 pm
[Ornella Jacobson] "Im sure there must be an effect or plugin to recreate this effect"
Nope! But there is a technique you can use.
  • Make a bunch of vertical bars in a nested comp using solids.
  • In the main comp, add a still of a paper texture -- plenty of those out there -- and put a circle mask on it.
  • Duplicate this layer.
  • Add the nested comp to the main comp twice -- one above each of the paper circle layers. Use the nested comp as a track matte -- one should be an alpha matte, and one should be an alpha inverted matte.
  • Animate the vertical positions of the two paper circle layers.
That's all there is to it.
Dave LaRonde
Promotion Producer
Tero Ahlfors
on Feb 2, 2018 at 11:09:42 pm
You could also use the vertical bars with the displacement map effect and only do vertical displacement. Or horizontal depending on the way you want to split it.
Jim Scott
on Feb 3, 2018 at 12:15:57 am
There is a script, Slice it Up for After Effects, that should do what you want if you don't want to do it manually:
https://aescripts.com/slice-it-up/
Sander Broos
on Feb 3, 2018 at 12:48:42 am
Actually there is a plugin that does just this: Wave Warp. Set the Wave Type to Square, increase the Wave Width so the bars are wider, and then keyframe the Wave Height to get the moving bars like in the example video!
Richard Garabedain
on Feb 5, 2018 at 5:36:07 pm
Kudos Sander Boo
