Recreate crude circle grid animation
Al Mach
on Jan 31, 2018 at 7:42:09 pm
I want to recreate the circle grid animation in the beginning of this video. I haven't been able to find any tutorials online that demonstrates how this can be done. It appears pretty simple. Can anyone help me get this started? Thanks in advance.
Eric Santiago
Re: Recreate crude circle grid animation
on Jan 31, 2018 at 8:45:33 pm
Spherize a solid with Grid applied to it.
Eric Santiago
on Jan 31, 2018 at 8:56:55 pm
Sorry I was a litte to quick on reply.
You can do this using an Adjustment Layer with Spherize applied at center.
Under the Adjustment Layer use a super wide Solid (20480x2048) and apply a Grid to it using Width Slider.
Animated the position from left to right (whatever floats your boat).
PreComp that and apply a Track Matte using a Spherical Mask.
Use that Comp and apply on any layer of your choosing.
Does it look great...not really.
I would have done this in Maya.
Im just lazy that way ;)
Richard Garabedain
on Jan 31, 2018 at 9:29:18 pm
grid plus cc sphereize
Al Mach
on Jan 31, 2018 at 10:00:04 pm
Thanks for this. I've never used a width slider before so not sure how to do that. But I did everything else, and the grid showed up. The problems I have are:
1) The lines on the y axis show a fake perspective because of the sphere effect. I want the vertical lines to be the same width throughout.
2) Don't know how to skew the grid so it's more oval, and not a perfect circle.
I thought this would be easier than it actually is. Is it possible to do what I'm describing without frame-by-frame animation?
Dave LaRonde
on Jan 31, 2018 at 11:44:26 pm
....and here's another way to skin this cat.
  • Make a square-pixel SOLID that's twice as wide as it is tall.
  • Apply the grid effect and adjust to taste.
  • Precompose it, matching precomp dimensions to the solid's dimensions.
  • Add CC Sphere to the precomp, now in another comp.
  • Animate the effect's Y rotation.
  • Precomp again.
  • On this new precomp, change its y-scale only to flatten it a bit.
And there you go.
Dave LaRonde
Promotion Producer
