Recreate video effect.
Jacques Hard
on Jan 29, 2018 at 5:41:46 pm
Does anybody know how to create the effect in this video:
Dave LaRonde
Re: Recreate video effect.
on Jan 29, 2018 at 7:05:07 pm
I only watched a minute, but which effect of the five I saw are you curious about?
Dave LaRonde
Promotion Producer
Jacques Hard
on Jan 29, 2018 at 7:25:10 pm
Hi Dave!
I find it hard to explain, but the way the pixels shift/move in clusters.
- Jacques
Dave LaRonde
on Jan 29, 2018 at 9:08:00 pm
You can to that by masking a solid in a comp that's intentionally smaller than the final comp. Animate the mask and use Hold keyframes to make the mask jump every few frames. Then nest this comp inside the final comp and scale it up to fit the comp.
The result -- recognizable pixels moving erratically.
If you want the pixels to NOT move erratically but at regular intervals, you can change the frame rate of the comp to a rate much lower -- perhaps 6 or 20 frames per second.
Dave LaRonde
Promotion Producer
Jacques Hard
on Jan 30, 2018 at 7:14:55 am
Thank you Dave, very helpful. I'll give it a try!
- Jacques
Jacques Hard
on Jan 30, 2018 at 9:59:23 am
Hi again Dave, I couldn't quite get it to work...
Could you elaborate the method more simple?
- Jacques
Dave LaRonde
on Jan 30, 2018 at 7:18:11 pm
I'm sorry, but my description is already as simple as it gets.
Dave LaRonde
Promotion Producer
Walter Soyka
on Jan 30, 2018 at 11:36:20 pm
This looks like a technique called "datamoshing" to me, plus some aggressive grading (maybe even just Threshold & Tint).
Datamoshing isn't completely straightforward to do in Ae, but there are a number of tutorials on the topic. Unfortunately I don't have a specific one to recommend, but hopefully knowing the term will help you find one.
Walter Soyka
Jacques Hard
on Jan 31, 2018 at 12:08:58 pm
Thanks Walter
I'll look into it, just knowing the term is very helpfull!
-Jacques
