How to fix "blocky" blur?
John Eggers
on Jan 28, 2018 at 7:05:28 pm
Hey all,
I am currently working on a project where I am creating a spotlight from a masked white solid. The spotlight is supposed to have a very large falloff, so I applied a Gaussian blur of about 200 to it. However, upon doing so, it ceased to be a smooth blur and is instead a series of several very defined segments going from bright to dark. It gives it a very pixelated and blocky appearance to the edge of the mask that is very undesirable. I looked to see if there was a way to turn up samples (thinking that might be the problem), but I can't find that either. Is there a fix for this? I tried feather and box blur too, and the results were the same. Any help is appreciated!
John Muehl
Re: How to fix "blocky" blur?
on Jan 28, 2018 at 7:52:07 pm
Are you looking at your preview or an exported file? It could be the Bit channel settings of your project. If your looking at an 8 bits per channel project then you'll see less quality in sacrifice for quicker render speeds. Hope this helps.
John Eggers
on Jan 28, 2018 at 8:09:37 pm
It was at 8-bits, so I just changed it to 32. I looks much better than before (the blockiness is much less pronounced). However, there is still a bit of it there. It there no way to fully get rid of this, or is there one more similar setting that I am unaware of?
