Difference between "Empty Disk Cache" and "Clean Database & Cache"?
Filip Stillerska
on Jan 27, 2018 at 3:12:47 pm
What's the difference between "Empty Disk Cache" and "Clean Database & Cache"?
Jim Scott
Re: Difference between "Empty Disk Cache" and "Clean Database & Cache"?
on Jan 27, 2018 at 6:59:51 pm
Maybe this will help:
https://helpx.adobe.com/after-effects/using//memory-storage1.html
Filip Stillerska
on Apr 13, 2018 at 5:30:32 pm
To be honest with you, I still don't understand the difference. Please help!
Kalleheikki Kannisto
on Apr 15, 2018 at 7:03:14 am
I'd say this is the key point there to explain the difference
Clean Database & Cache: This command only removes files associated with footage items for which the source file is no longer available.
Senior Graphic Designer
