1080x1920 comp - Mercury transmit at 1920x1080 for vertical viewing?
Daniel Christie
on Jan 27, 2018 at 2:53:34 am
I'm wondering if there is a way to rotate the external video output (via Mercury Transmit and Black Magic card) 90° so that I can work in a comp that is vertical (1080x1920) whilst previewing on a monitor that has been rotated to stand vertically.
Many thanks,
Daniel
Joe Ribal Nasr
Re: 1080x1920 comp - Mercury transmit at 1920x1080 for vertical viewing?
on Jan 27, 2018 at 6:39:50 pm
Subnest the 1080x1920 and put it in a 1080p timeline then rotate it -90°
Dave LaRonde
on Jan 27, 2018 at 11:48:40 pm
Normally, I would work in a 1080 x 1920 comp and then nest it in a 1920 x 1080 comp. The trick -- knowing whiich way to rotate the nested comp. Find that out and you're golden!
Dave LaRonde
Promotion Producer
