Retro "Blinds" Transition Effect from Lethal Weapon trailer
Daniel Bent
on Jan 23, 2018 at 11:27:48 pm
Hello everyone,
I'm trying to accomplish this effect, anybody know on how to create this "blinds" transition? You know the thin to thick lines or strokes, not satisfied with the bulit-in AE plugin venetian blind effects :/ If anyone knows how could help, that will be appreciated! 😉 Thanks!
- Daniel B.
Source to what I'm talking about:
Kevin Camp
Re: Retro "Blinds" Transition Effect from Lethal Weapon trailer
on Jan 23, 2018 at 11:43:57 pm
on the original open, it looks like a simple mask or track matte layer with the pattern that is animated across the screen.
for the newer tv show version you might look at using card wipe on a solid and use the solid as a track matte. setting card wipe 'rows' to 1 will make vertical lines (or cards), setting the flip axis to 'y' will get the rotation needed and setting the back layer to 'none' will keep the solid from wiping back on.
make the solid larger than the comp to avoid seeing the top and bottom edges of the 'cards' as they rotate and also allow you to angle it to match the example.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Daniel Bent
on Jan 24, 2018 at 1:39:28 am
Perfect! Thank you so much! 👍
-Daniel B.
Michael Szalapski
on Jan 25, 2018 at 6:30:43 pm
There's also the Venetian Blinds effect.
- The Great Szalam
