I can't find "position XY" in trapcode
Manuel Juarez
on Jan 23, 2018 at 6:27:24 pm
I'm trying to make the dr strange 's portal with a tutorial. I've download trapcode for using the particular effect but I can't find this option. Someone can help me?
In this and other tutorials it appears like this:
I'm new in all of this and I really want to learn so thank you and sorry for my bad english.
Cassius Marques
Re: I can't find "position XY" in trapcode
on Jan 23, 2018 at 7:19:01 pm
Your "Emitter" is set to Lights, its position should be any light's position. Change from Lights to Point to enable the position property to be set.
Cassius Marques
http://www.zapfilmes.com
Cassius Marques
on Jan 23, 2018 at 7:21:49 pm
Your "Emitter" is set to Lights, its position should be any light's position. Change to point to enable the position. Though you won't have position XY. Newer versions of particular use a 3 array property. [X,Y,Z]. But you should be ok following the tutorial.
Cassius Marques
