updated auto flicker and smart frame blend for cc 2017
Chris Wright
on Jan 20, 2018 at 10:04:38 pm
updated auto white balance and flicker removal for ae cc 2017 and minor bug fix division by zero. 1440x1080 1.0 framerate 16 fps comp.
https://f1.creativecow.net/12087/auto-white-and-flicker-ae-cc2017-template?...
updated:
Convert 16 fps to 24fps using smart frame blend. it only blends every 3rd frame using 50% not adobe's 25%/75% for higher quality frame conversion in AE. as optical flow doesn't work well. also, has built in scene detection for using whole frames on cuts!
https://f1.creativecow.net/12086/16fps-to-24fps-with-smart-frame-blend?uplo...
