How to have multiple camera angles all displayed on the same comp
Scott May
on Jan 19, 2018 at 1:22:42 am
Goal is to make hologram content for a phone, like this:
I am using Element 3d, 4 cameras showing front, back, left and right. I would like to be able to show each camera's view in a single composition. Does anyone know of a way to do this? I have come up with ways but nothing that makes the overall process simple (having 4 comps with a different camera does not make it easy to edit)
Each triangle would be a masked comp of a different camera view.
Thoughts? Thanks in advance for any ideas.
Dave LaRonde
Re: How to have multiple camera angles all displayed on the same comp
on Jan 19, 2018 at 5:17:03 pm
After Effects can only have ONE active camera at a time.
You'll have to prerender each different camera view to achieve what you want.
Dave LaRonde
Promotion Producer
Cassius Marques
on Jan 19, 2018 at 5:43:52 pm
Have four diferent compositions, one with each camera active. Composite them on the final composition.
Cassius Marques
http://www.zapfilmes.com
Scott May
on Jan 19, 2018 at 6:21:09 pm
That's what I figured I would have to do.
My current solution is to have one composition with 4 cameras. Each camera is active for 10 seconds with the 3d animation looping every 10 seconds. I then put this comp into a new comp 4 times, with each instance being a different 10 second interval.
The idea here being I only have to edit that one comp rather then 4. I guess this will work for now. Thanks guys
