Huge heavy file with proxy
Luca Bej
on Jan 17, 2018 at 12:48:20 am
I'm testing a proxy in a test comp but when I export and I choose to use proxies my output file is 1,5GB, if I don't use them, my file is 600mb instead...
Is that correct? Both files should be the same!
Anyway....
I think that could happens as my proxy file has a low resolution and when AE try to render a low-res file making it bigger, every frame has more colors informations due to blurredness of the smaller movie/proxy that is now stretched and made bigger... Am I right?
Tero Ahlfors
Re: Huge heavy file with proxy
on Jan 17, 2018 at 7:01:06 am
[Luca Bej] "Is that correct? Both files should be the same!"
You didn't say anything about your source formats, composition settings or your export settings so it's impossible to say.
