Change rotation to all keyframes after motion tracking rotation
Pim Beune
on Jan 14, 2018 at 1:31:43 pm
Hello guys, first of all, I'm new to the game.
So, I have a video, in which I want to motion track both position and rotation.
This went all fine, but the object I applied the tracking to, is rotated in a way I don't want.
If I change the rotation of a single keyframe, it only applies that to only that keyframe.
How do I change the rotation of all keyframes of the object, without changing the tracked rotation?
Thanks in advance.
Kalleheikki Kannisto
Re: Change rotation to all keyframes after motion tracking rotation
on Jan 14, 2018 at 4:46:13 pm
The easiest is to set the current time (playhead) to one of the rotation keyframes, then select ALL the rotation keyframes and then change the rotation by dragging the value. This will affect all selected keyframes by the same amount.
Senior Graphic Designer
Pim Beune
on Jan 14, 2018 at 5:35:02 pm
Thanks for your response,
How do I select all rotation keyframes? I can't get it to work.
Mark Whitney
on Jan 14, 2018 at 5:59:31 pm
With the Rotation property keys exposed, simply left mouse marquee select, or simpler yet just click on the word Rotation.
Pim Beune
on Jan 15, 2018 at 3:31:23 pm
Thank you very much. Everything is working now.
