How do i scale a shape layer while keeping the proportions of the edges?
Ornella Jacobson
on Jan 14, 2018 at 12:28:11 pm
I have a circle with an edge around it, and i want to scale it in one direction, until it becomes one flat line.
If I just transform it, the edge will distort, but i want to keep its thickness even.
I'm sure this has a super simple solution, but I just can't figure it out.
Any advice?
Thanks & Cheers
Ornella
Kalleheikki Kannisto
Re: How do i scale a shape layer while keeping the proportions of the edges?
on Jan 14, 2018 at 4:47:31 pm
Change the size values of the ellipse rather than the scale.
Senior Graphic Designer
Ornella Jacobson
on Jan 14, 2018 at 5:17:38 pm
Thank you, that worked! But now if i want it for a path that i drew with the pen tool, there's no size value to change. You know how to fix this?
