How to: Multi-Image Pan
Nathan German
on Jan 11, 2018 at 8:35:57 pm
I'm curious if anyone has any input on how to create a multi-image pan effect in After Effects similar to what is seen at the 1:23 mark in this video:
So far, the best method I have come up with is to simply arrange the images manually in 3D space, create a camera, and then animate the position of the camera to pan across the images, but I feel like that would take forever just laying out all the images. Anyone have any other method suggestions that may work quicker or more effectively?
Dave LaRonde
Re: How to: Multi-Image Pan
on Jan 11, 2018 at 9:06:47 pm
You don't HAVE to use a camera for this. But you do have to arrange the layers in 3D space. Then parent them to a 3D null, and animate the horizontal position of the null.
A smart AE guy once quipped that they call it 3D is because it takes three times as long to set things up.
Dave LaRonde
Promotion Producer
Walter Soyka
on Jan 11, 2018 at 11:24:17 pm
You could use a particle system. Precomp and sequence all the images as a single frame each inside of a comp, then use that with "Random Still" mode as the texture for your particle.
Or you could build the random assortment of photos with a script like this:
https://aescripts.com/distributelayers/
Or you could use an expression to randomly distribute the photos in space, then animate a camera or link them all to a null and pan it:
// adjust these values to taste
minX = -2000;
maxX = 2000;
minY = -1000;
maxY = 1000;
minZ = 0
maxZ = 2000;
seedRandom(index, true);
value + [random(minX, maxX), random(minY, maxY), random(minZ, maxZ)];
Walter Soyka
