After Effects panels UI flicker/duplicate when resized
Marko Sutlar
on Jan 10, 2018 at 10:02:57 am
I have a problem with UI flickering/duplicating when I try to resize panels.
Here is an example
The weird thing is that this is happening on every single AE version (that I tried) from CS6 to CC2018.
Here is my PC:
Windows 10 latest updates
i7 2700k @ 4.2ghz
16GB DDR3 ram @1600mhz
GTX970 Asus Strix @stock
Latest nvidia drivers 01/08/2018
I did a clean reinstall of after effects, I did a clean install of drivers, nothing helps. I contacted Adobe support and they said to upgrade RAM but I'm pretty sure 16gb should be more than enough in an empty project and with only 400mb being used by Adobe.
Dave LaRonde
Re: After Effects panels UI flicker/duplicate when resized
on Jan 10, 2018 at 10:15:50 pm
I would classify this as a VERY minor annoyance, and nothing to worry about. If that's the only AE problem you're having, consider yourself lucky!
Dave LaRonde
Promotion Producer
