hold frame icon appears flipped/backwards i.e. hold then linear out.
Charlie Canfield
on Jan 6, 2018 at 2:36:46 am
weird thing i've never encountered with a hold frame on a layer (jpg in this case):
instead of usual hold icon with 1/2 diamond left side (linear in) and then square right side (hold) it is appearing opposite/backwards with square left side and 1/2 diamond right side, which results in linear movement along the timeline!
and it gets curiouser: if i paste a normal hold frame from another layer into the jpg layer, it still flips to that opposite/backwards hold!! and- where we would usually get a complete square hold icon after the first linear in/hold icon, this will create a square BEFORE the opposite/backwards hold frame!
here's a pic:
Walter Soyka
Re: hold frame icon appears flipped/backwards i.e. hold then linear out.
on Jan 7, 2018 at 11:28:17 am
Time is running backwards for that layer, because you have "Time-Reverse Layer" enabled for it -- note the blue/gray marks at the bottom of the layer.
Select the layer and press Ctrl+Alt+R (Windows) or Command+Option+R (macOS) to toggle Time Reverse.
https://helpx.adobe.com/after-effects/using/time-stretching-time-remapping....
Walter Soyka
