Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
manojit ghose
on Jan 3, 2018 at 1:48:27 pm
SUB: Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
1. rendered a multipass tif (PSD layers) seq.
2. wanted to import the sequence either in photoshop or in after effects (keeping all my layers( passes)) -
3. doesn't seem to work when i import the sequence.
anyone knows any workaround (i know i can render other formats) or tips to make this work.
please feel free to ask any question in case i was not very clear in explaining.
thanks in advance cows ☺
m.
MG
Walter Soyka
Re: Opening a sequence of tif (PSD Layers) files in photoshop or after effects?
on Jan 3, 2018 at 5:16:31 pm
[manojit ghose] "anyone knows any workaround (i know i can render other formats) or tips to make this work."
Instead of rendering the multiple passes to a single, multi-layer Photoshop image sequence, render each pass to its own, separate image sequence. You can then import each pass as a separate image sequence and composite them together.
Walter Soyka
manojit ghose
on Jan 3, 2018 at 8:14:07 pm
hi walter
thanks for your reply...i knew that way infact that was my backup!... I was just curious if there is a way to make the multilayer tif (PSD layers) work in a timeline, i like the ease of handling vis-a-vis exers.
thanks
m.
MG
