Slider effect problem
Thom Buiting
on Jan 3, 2018 at 1:09:58 pm
Hi all,
Currently I'm working on a animation but something isn't working out.
I have one text layer (SHOTSPEED 0 KM/H). In this layer I want "0" to slide up to "100".
If I use Slider Control it affects the whole text layer which is not what I want because then I'll lose the words.
Does anyone know how to put the Slider Control (or something similar) only on the 0 without using multiple layers? If I use multiple layers I can't get the spacing between the words right.
Hopefully someone knows the answer 😄
Cheers,
Thom
Walter Soyka
Re: Slider effect problem
on Jan 3, 2018 at 5:14:30 pm
You need to use an expression that includes the value of the slider inside your text string, like this:
"SHOTSPEED " + parseInt(effect("Slider Control")("Slider")) + " KM/H"
Walter Soyka
Thom Buiting
on Jan 3, 2018 at 5:28:35 pm
Thanks Walter, that's just wat I needed! 😃
