What's going on in this strange animation??
Don Johnson
on Dec 24, 2017 at 6:00:54 am
Apart from the dithering, what's going on in this video? I can't work it out it's as if some sort of kaleidoscope effect is happening? Confused!
Kalleheikki Kannisto
Re: What's going on in this strange animation??
on Dec 26, 2017 at 7:41:21 am
Looks like pixel motion frame blend, possibly from separate source footage, and a posterization effect, which can be done with curves.
Senior Graphic Designer
Don Johnson
on Dec 27, 2017 at 3:58:56 am
Interesting, how do you do a frame blend using separate source footage??
Thanks for your help!
on Dec 30, 2017 at 3:11:34 pm
Well, that's what it looks like, but it's not really possible to use a different source in After Effects. What I would try is the following, assuming the video is 6 seconds long (I didn't time it):
1) take still images of the video, at even intervals, about 1 second apart (so 6 or 7 stills for 6 seconds)
2) make a video from those frames
3) stretch the 6-7 frame video to the original length using pixel frame blending
That might end up looking similar to this effect.
luke dwyer
on Jan 1, 2018 at 7:32:50 am
Weird! Might be an animated find edges filter with a color ramp or tint
http://www.lukedwyer.com/
